Rmack1's avatar
Rmack1
Furnace malfunctioning
My furnace stopped coming on in the middle of the night, so I had to use the stove for awhile. I kept a fan on, and a small window open to vent any excess CO. Not an efficient way to heat.
Later, I moved the thermostat back and forth again, just to see if anything would happen, and it came on. Doing this in the middle of the night didn't work.
Next night, after working for most of the night, the same thing happened, only this time I can't get it on again after several tries.
It makes a click in the furnace when I move the thermostat back and forth, but no fan.
I have plenty of propane. Even if I run out, it still would blow, so I think it's something with the furnace itself.
Anyone have any idea what I'm looking at?
  • Furnace fan is a battery eater - when batteries get depleted the fan slows down and eventually the sail switch closes which shut down the furnace. Common for furnaces to shut down in the middle of the night when batteries are iffy. Check your batteries. If your connected to shore power then this likely doesn't apply.
