Bigdog
Apr 05, 2017Explorer
furnace, no heat
Got to our campground this last weekend and set the thermostat for the night. Woke up several times and heard the front funace running,which was fine as it was cold and windy. The next morning I found the furnace fan was still running, but no heat. I turned it off and then set the thermostat to 80, the furnace came on, but never fired and just kept running instead of shutting off after a few minutes.. Not a factor of no propane as the fridge, the water heater and the stove all worked fine and they're on the same pipe.
Rear furnace is working fine.
