dougrainer
Nov 28, 2019Nomad
If you have Dometic(2002) Tiffin was using Dometic. I have NEVER seen a upper control board be bad and not show a function. Odds are, the upper control board Furnace DIP switch needs to be turned Off then ON, to verify communication. IF you have had a repair on the front AC recently, then the Installer may not have turned the Furnace DIP switch ON. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
