dougrainer
Nov 29, 2019Nomad
NoSnowInAZ wrote:
I disagree with Doug being a "professional given his attitude.
You ask for help, You IGNORE it. Yes, it is a PITA to try and help people that have no idea what they are doing and refuse to accept help. You need to check and reset the Furnace DIP switch, EVEN if you have not touched it. There are 2 BLUE wires at the AC control board. ONE should have 12 volt power. IF NONE have 12 volt power your Furnace 12 volt fuse is blown or disconnected. MY attitude is, I give FREE help and then you do NOT follow the free help. So, I am the problem? Doug
PS, AFTER the DIP switch check and reset, you do a Wall Tstat reset to restore any missing appliance mode. Sorry, I guess you knew that.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
