darsben
May 15, 2016Explorer II
1) Sail switch stuck.
2) As furnace is 12 volt I would check for a blown fuse
3) apply power to the relay terminals and see if you get continuity across the circuit you are trying to control. Usually with a VOM.
Since you are rather careless I would call a good RV repair guy to come to you and diagnose the problem
MAY BE CHEAPER IN THE LONG RUN
