Kayteg1
Apr 06, 2016Explorer II
The furnace is using 12V coming from converter, so it is using 120V when it is available.
When propane is needed to generate the heat, some use furnace blower to spread the heat from electric heaters.
Electric heaters not only give uneven heat, but the heat will not go into tank bays, so when in freezing temperatures, running furnace blower might be advised.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
