Bobbo
Apr 07, 2016Explorer III
Kayteg1 wrote:
The furnace is using 12V coming from converter, so it is using 120V when it is available.
The furnace is using 12v, not 120v. Put a VOM on the furnace, anywhere, and all you will ever see is 12v.
The source of the 12v can be the battery, or the converter, but either way, all the furnace sees or uses is 12v.
Now, the CONVERTER uses 120v.
