- westomExplorer
Gasman wrote:
It is just amazing how so many of these simple questions turn into a pissing match about who is smarter.
Only one person makes this a pissing match. Identify the only one who is an adult acting like a child. According to his reasoning, all my appliances operate on 500,000 volts since they are powered from those high voltage transmission lines.
Also just as silly is to portray a meter (VOM) as too complicated. - Bob_LandryExplorer
And the end result is that after 4 pages of comments, the furnace still works on propane and 12VDC, either from the converter or the battery.
These tech threads just keep getting better and better. - BobboExplorer III
Kayteg1 wrote:
You don't want to see the big picture.
Converted voltage is converted voltage, still it is the source that should count.
If you want to split hair, often furnace has build in converter what supply 3-5V to control board.
So following your logic you can say that furnace runs on 5V.
Than RV converters give about 14V not 12.
Furnace voltage? Furnace Manual. See page 3.
That answers the question completely, and with authority. - Old-BiscuitExplorer III
Boon Docker wrote:
Just too many arm chair engineers on this forum. :B
Or some that were actual engineers with information that can clarify 'misinformation' which Helps ALL
Daddy always said:
Ignorance and misinformation are 2 things that can be corrected
Now 'stupid' well there just isn't any hope - Kayteg1Explorer II
or try to pretend being smarter by posting something that brings nothing to the subject :)
I don't take it as pissing match to start with.
If something in this World has simple technical answer, I did not meet it yet.
No matter what decision we have to make, it is never "black or white" but the choice is from multiple grades of gray.
Exchanging our opinions let us better understand possible options.
In this case main disagreement seems to be English understanding.
Is "runs off" "run on" and "powered by" the same thing? Doesn't look like. - Boon_DockerExplorer III
Just too many arm chair engineers on this forum. :B - rgoldingExplorer
I was just thinking the same thing.
Our a/c units have heat exchangers, so they do work as a furnace. Nice but noisy. We use 2 spacer heaters for heat source on nasty, wet, damp days like today. Keeps the chill off. If its below freezing, we do cycle furnace to keep stuff warm below, but space heaters for local comfort.
We also use an extra 20amp circuit on a surge protector power outlet off the power post in the campground. That way we can run 2 space heaters and not trip a breaker. - GasmanExplorerIt is just amazing how so many of these simple questions turn into a pissing match about who is smarter.
If you want to split hair, often furnace has build in transformer what supply 3-5V to control board.
Not a Suburban or Atwood RV Furnace.
They do have a transformer but that boosts voltage to 10K for spark electrode
RV Furnaces operate on 12V DC power...regardless - Kayteg1Explorer IIYou don't want to see the big picture.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
