Hey guys, sometimes my furnace wont heat, it push room temp air for 30 sec or so and then it stop blowing. when it stops my 2 fans for blowing hot air into the basement for heating tanks dont s...
Your furnace rely's totaly on a 12v supply. When it gets around 11v the fan can slow down to the point it no longer activates the sail switch which sends a signal to the gas valve that the fan is blowing and it's safe to fire the burner. Also a low battery will cause issues with the circuit board on your refrigerator in the same way. The only way to correct this is to keep your battery charged, either a generator, solar, or plug in your truck and run for a good while.
