BlanchExplorerNov 02, 2020Furnace ProblemsMy furnace will work if it is not plugged into shore problem. If I unplug it, the gas ignites and the furnace works. Plugged in, I hear it attempt to light a couple of times then it shuts down. Any su...Show More
enblethenNomadNov 02, 2020Verify the voltage at the furnace when plugged in and when running on batteries.Possible converter is failing.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
Related ContentAtwood Furnace Problemsdometic furnace problemFurnace problemfurnace problemsAtwood Furnace Problems
