time2roll
Jan 20, 2017Nomad
Mine cycled the burner due to inadequate and poorly installed ducting causing an air flow restriction.
If you have basically bench tested the furnace and it still overheats the firebox I have to speculate internally restricted airflow or the fan/motor is not performing properly. If it is old I would just replace. Check the component warranty if it is not too old.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
