pirlbeck
Jan 21, 2017Explorer
Is the blower fan a squirrel cage style? If so, be sure the squirrel cage fan is installed properly. If the cage is installed wrong or the motor rotation is backwards they will still move air, but not nearly as much as they should. I work on farm equipment and all the heating/AC systems use squirrel cage fans and I have seen this problem a LOT of times over the years. What would appear correct by looking at the cage may not be the correct way.
Do a Goggle search for "squirrel cage fan rotation" and start reading.
Here is one comment I found.
"A squirrel cage running backwards produces about 25% of the air flow it should when turning the proper direction."
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
