dougrainer
Feb 01, 2017Nomad
rogerck wrote:
A blank, unused hole plug ( four inch round) for the outlet air distribution openings. This item was wedged directly in between the blower outlet and heat exchange where you've drawn the blue outline. Sloppy assembly. You wouldn't see it if not looking for it.
What they did was, they knocked out the metal duct hole cover and just let it fall inside. Yes, sloppy install. I do not understand why you did not see it from inside where the hi limit switch is and looking over the combustion chamber to the blower. Unless you were not sure what a normal furnace would look like. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
