Great information Doug, I'll test the regulator as per your suggestion. Thanks!
I took the RV to the shop specifically asked them to test the regulator. When he called me later in the day to give me the results, I asked if the regulator was OK and he said "the pressure is good". The invoice says "ran LP system check, pressure test, leak down test, all passsed. Held for 20 minutes at 12 in WC". It's been working fine but not confident it will last. If/when the problem returns, I will test regulator and inspect orifice.
