time2roll
Oct 05, 2014Nomad
Blanco1 wrote:Converter is generally in close proximity to the main fuse and breaker panel.
Where would I find the converter & how would I check it?
If you have about 13.6 volts at the fuses the converter is fine.
Now you need to remove the furnace for inspection. If you are not comfortable with that you will need to go in for service.
There is no external knob or switch that is going to resolve the furnace trouble.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
