Harvard
Dec 30, 2014Explorer
If related to battery operation then most likely a low voltage sail switch issue.
If not, could be an oil trap in the copper line to the furnace IF it works when warm (lower viscosity) BUT not when cold (higher viscosity). This type of issue is probably more common with using propane bottles then with frame mounted propane tanks..
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
