Blanco1
Dec 30, 2014Explorer
smkettner wrote:
oldbeek, I have to agree with Suburban that you have restricted ducting causing the high limit switch to open. Mine does the same but I don't think mine cuts out at six cycles. Mine runs a long time with about 2 minutes burner on and 1 minute burner off. I have also added an additional duct but have not tested it yet. I have an OEM board not a Dinosaur.
To the OP, can you tell if the burner is cycling while the blower continues to run?
To be honest these last two post are much more technical than I understand?
Yet appreciate it, in time I 'll start understand your lingo. :)
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
