JaxDad
Dec 31, 2014Explorer III
Blanco, the translation is;
First, the furnace has a sensor which turns off the heat, but leaves the blower going, if the furnace gets too hot.
Secondly, they're asking if the burner keeps trying to start when the blower is running. The difference is there's a micro swith in the furnace called the "sail switch". Basically it's got a little tab connected to the switch, the tab sticks out into the airflow of the blower. If there's enough air flow (which pushes the switch shut) to safely allow the burner to run, it does. If not the burner will never light. If your batteries are low the blower motor turns too slowly and doesn't make enough airflow to close the switch.
The simplest, read very low-tech, test is when it's the coldest light every burner you have, put them on highest setting and see if a) they even light, b) get to full output, c) stay lit and at full output. NB: you may need to crack a window and / or put on the exhaust fan.
If you get less than perfect results from the above you'll know straight away it's a gas problem.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
