allersj's avatar
allersj
Furnace using too much propane
This all happened last spring, but I never addressed the issue. Our first day/night of camping was chilly. When we got to the camper, the temperature was about 50 degrees. I started the furnace, we went out to dinner, and by the time we got back, the camper was comfortable. For sleeping, I set the thermostat at 65. The temperature that night got down to 30. We awoke at 5am freezing. We were out of gas. I was positive that the tank had been full, but was cold enough to not care at the time. I went out and switched over to the other tank. Heat came back on. The temperature that day got to 65. The furnace didn't run much at all. That night got down to 30 again and I woke this time at 4am, once again freezing. I was pretty sure that my second tank was full, but admittedly I didn't check it the previous morning. I luckily had a spare 3rd tank. I know this one was full. I connected that and got the heat back on. Fast forward to the next (early) morning, and that tank is now empty as well. I went through 3 thirty pound tanks in 3 nights. The long weekend was over and our next trip back wasn't for a few weeks, so the weather was warmer. The remainder of of camping that year, we used electric heaters as needed. I leak checked all the connections and all the pipes. Nothing. The other two other things in our camper that use gas are the hot water heater and the stove. We used those for the whole summer and only went through 1 thirty pound tank.
So, here's what I know: the furnace alone is the culprit. But what I don't know is why. If it's a gas leak, it's only when the furnace is running. But it seems like if there was a gas leak right there at the furnace, something would have ignited. (Insert "shudder" here) Could something cause a furnace to run so inefficiently that it would use that much gas?
I'm going to guess that the number one suggestion will be "You should take it in." Because that would be my suggestion. There's a few reasons that's not going to happen: it's very difficult to get it out of its permanent site, the trailer is not plated, the nearest repair place is over an hour away, I wouldn't trust the tires to go 10 miles, etc. Also, I'm somewhat handy, so if the options are taking it someplace or installing a new furnace, I'd chose the latter. And I do feel that if I know what I need to fix, clean, or replace I could do it myself. I just don't know what to look for or where to start. I'm hoping someone has had a similar experience and can point me in the right direction.
Thank you.
  • I should also note that we have camped years prior during cold spells in this unit, and it had never used propane like this.
  • jdc1 wrote:
    Average RV heater uses about 1/3 gallon of fuel an hour. 30* weather? More than that. A 30 pound tank is 7 gallons. Expect only 14 hours out of a tank in those conditions.
    It only got that cold at night. I'd say I went through a 30lb tank in about 7 hours. Also, the furnace would run, heat up the camper, then shut off. It wasn't running non-stop.
  • Two easy suggestions:
    1. Check the color of the flame. It should be blue. Orange flame means too much air. That can be adjusted.
    2. Check all pipe connections with soapy spray to see it there are any leaks.
  • That is a lot of propane. How big is the RV?
    I would check the ducting to verify the heat is all getting to the living space and not lost to some compartment or to the exterior. Unfortunately much could be hidden so check the volume of air. Yes if it will be close to freezing or below we run a space heater continuous to supplement the furnace.
    If there is a leak the most likely place is the regulator. If it is over 5 years old it would be OK to just replace it. Also the regulator should switch cylinders automatic so there is no waking up freezing and running outside to change cylinders. Check the indicator and fill every day if needed during a cold spot.
    I prefer the Cavagna brand regulator. Amazon $100
    Get new pigtails at the same time.
  • jdc1's avatar
    jdc1
    Explorer II
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
