ford_coupe's avatar
ford_coupe
furnace won't light
Good chilly morning to all. furnace in our 5'er won;t light,worked ok till last nite. as far as I can see no way to get to it,in cupboard under sink. no access out side,just vent & exhaust. checked propane both tanks have plenty stove burns good. any thoughts b/4 I call mobile repair?
  • `had rv repair guy come,crawled into area had me turn up thermostat & funace came on, thinks I had air bubble in line. thanks to all for your help
  • You need to locate the make and model of the furnace!
    It is possible that it is dirty and needs to blown out or vacuumed good. The sail switch maybe inoperative. Could be bad circuit board or high temperature cut out.
    It is hard to say with out make and model to help.
  • ron 3rd.blower comes on, no heat can't see any circuit board, will check propane bottles, 5'er is 2008
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    What model furnace? Does the blower come on but no heat? If so, it could be the sail switch. Blower does not come on? If so that's a different set of potential problems including a bad circuit board.
    Most are remarkably simple in design and operation and there's only 2-3 things that ever go wrong with them. If you can see the circuit board and it's a newer generation furnace, it will have LEDs on it that flash an error code. You can then look up the code in the manual. If you can get access to them, they're normally pretty simple to fix once you figure out what the problem is.
  • I actually had an issue where my stove would light but furnace wouldn't because tanks were near empty. Lift the tank to make sure there is plenty of propane in it.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
