andyrc's avatar
andyrc
furnace/hotwaterheater wont kick on
I have a trail cruiser 2004 c-21rbh trailer. The stove works, but the furnace won't light and it's fan won't kick on. Also, the hot water heater won't light. I'm guessing there is a fuse, but all of the fuses inside the trailer look solid. what am i missing?(other than a clue)
ac
  • 12 volt DC fuses are normally located behind metal plate adjacent to the 120 volt circuit breakers.
    Do you have a voltmeter or test light?
  • I assume you have a converter/charger that is contained in the power center. Saying you looked at the fuses I assume you found it. Have you actually tested the fuses, sometimes they look good but are burned out? Depending on the trailer and how it was designed the furnace and the water heater could be sharing a fuse.
  • Oh, also, i DO get power in the trailer when im not plugged in. The lights still work.
  • Ok, any idea where that is located? not in with the battery and i followed the red cable from the battery and didn't see one.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
