dpgllg
Apr 13, 2018Explorer
RSD559 wrote:
My Furrion pre-wire provides power when the trailer is plugged into the tow vehicle. I have heard from others that it is on whenever there is battery power. Only way to tell is to check for power with a meter when it is not hooked up. Or you can plug in the camera and see if the LED lights up. I believe there is a LED to indicate power.
Thanks!
Well if I put in a battery disconnect it will take care of this because all other times I will be hooked up to tow or connected to shore power as we do not dry camp
Dave
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
