GordonThree
Jul 19, 2016Explorer
hedge wrote:
Would it be a bad idea to use a fuse block like below as a way to combine the wiring from my panels (parallel). Of course it would have to be mounted in a waterproof container but it would be handy if I chose to fuse each individual leg (I know that may not be strictly necessary but I'm a belt and suspenders kind of guy).
The one thing i don't like is that it would need ring terminals on the wires, not sure how much resistance they would add.
thoughts?
I agree with 2oldman ... should work fine, but overkill. Something like this still provides convienence, without the fuss of fuses:
http://www.ceshowroom.com/ProductDetails.asp?ProductCode=CWR20224
My thinking is, although designed for marine, all those fuse connections provide more places for corrosion to set in and rob you of precious solar power. You only need one inline fuse, before the charge controller, to protect the feed in from the roof.
I would not use a waterproof box, as it will trap humidity inside, aiding corrosion. Just use a plain junction box, so any water that makes it in will also make it out. Mount it such that if water pools on the roof, it will not pool inside the junction box.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
