Searching_Ut
Jul 19, 2016Explorer
The setup you're describing is how I built my combiner box. Fuse panel that holds 6 fuses put into plastic junction box with a bus bar for the negative connections, waterproof strain reliefs for the wires coming in. I currently have 5 100 watt solar panels combining in my junction box, but recently ordered a 6th panel which I'll be installing when I get the chance.
The way solar panels work, if you short the output wiring out, the current flow doesn't increase enough to where a fuse would be likely to blow anyway. On the other hand, should power feed back through the panel for some reason the fuse could be of benefit to prevent a feed from the other panels in parallel, or the battery. I debated going without fuses, but after asking for recommendations on these forums decided to go with my initial instincts of adding them in.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
