Cydog15
Jul 14, 2018Explorer
wa8yxm wrote:
First the switch in the photo is a common DPDT center off rocker with as couple jumpers To replace it go to an electronics store and get a DPDT center off (Will be labeled (On)off(on) switch.
RUn a jumper from top left to bottom right, and from top right to bottom left.
Hook up same as it is now You may need to turn it upside down.
BUT... Before you do that.....
REmove the two CENTER leads (Label them right and left)
Cycle the switch like 50 times both directions.
Re-connect and see if it works.
Did you see he found it was a resettable CB, short stop.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
