red31ExplorerDec 05, 2016Fusing REQUIRED?consider 6A Isc panels with 10g wire parallel 3, 1.56 x 6A x 2 = 19A parallel 4, 1.56 x 6A x 3 = 28A with lower amp panels, one does not need to fuse until 10g rating is exceeded by the numbe...Show More
drsteveExplorerDec 05, 2016Are you asking if larger wire means you don't need fuses? Not a solar expert, but I'd say no.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
Related ContentFuse panel locateNew EPA RequirementsBraking system required?2 nights requiredTowing requirements
