sdetweil's avatar
sdetweil
FW front closet sliding doors won't stay on the track
We have a 2013 Keystone Alpine Front bedroom, with bath as the most forward room. there are two mirror front sliding doors that cover the whole front wall/closet . they have adjustable (up/down) rollers at the top of the door, and plastic guides that snap into a floor track at the bottom of the door.
everytime we go any distance, the doors will be off the tracks when we get there.
I have adjusted them up to have less space to jump out of the track at the top, but the bottom almost doesn't reach.. and adjusted them down to keep the bottom guides in, but the tops pop out pretty easily then.
this upcoming trip I am thinking of using so straps to keep the doors open. course any flying clothes will be all over the basthroom floor then too.
Montana 3910 FB is a similar model .
anybody got any guidance here that can help me? little over a week to go before we leave on next trip.
  • Take a couple of sponges and cut them to fit the space at the top. The more sponge material you can jam in there the better.
    I like the shim idea at the bottom.
  • donn0128 wrote:
    Take the bottom track off, and add a 1/4 inch shim under it. That should allow you to readjust the upper wheels. As an alternative it might be easier to hide shimming the top track.
    cool.. hadn't thought of that.
  • Take the bottom track off, and add a 1/4 inch shim under it. That should allow you to readjust the upper wheels. As an alternative it might be easier to hide shimming the top track.
