D_E_Bishop's avatar
D_E_Bishop
FW tank fills when fw hooked up via hose.
Our 2002 Winnie 32V water tank fills when hooked to shore water. All valves are in correct positions. I am looking for the exact location of check valve, if there is one. I looked at on-line PDF but not labeled clearly. I did not se any CV just V designations.
I know it could be a leaky valve and they are all plastic. Both shower faucets are shut securely. Any ideas.
  • dave17352 wrote:
    Now did it solve it instantly or after a while? :)
    You got me,dude. My kind of humor!
  • Water pump has an 'internal check valve' ---- a diaphragm ---- that seals off to stop backflow thru pump.
    Also if you have a 'Fill' valve it can be leaking thru
    Disconnect pump suction line and see if water runs out (back thru pump) when using city water.
    If it does......install a in line check valve (Shurflo has them) in pump suction line ($10-15) Problem solved.
    If no water ...then fill valve is leaking thru.
  • jjjandrbaker wrote:
    RWjSIM2003 wrote:
    you can also try running the pump for a while and sometimes that will free up the Check Valve in your water pump and stop the problem.
    X2 I had the same problem once, and running the pump for a while solved it instantly.
  • you can also try running the pump for a while and sometimes that will free up the Check Valve in your water pump and stop the problem.
  • Look for a check valve in the 12 volt water pump. If you can disassemble, maybe just dirt in the valve. Replacement pump heads can be found on ebay if needed.
Having RV issues? Connect with others who have been in your shoes.24,358 PostsLatest Activity: Feb 08, 2026
