JacksonSigns's avatar
JacksonSigns
G6A-4E Direct ignition gas water heater problem
Hello everyone. New here but not new to RVing. Having a problem with the hot water heater not turning off and releases the pressure relief valve. It is an Atwood Direct ignition gas water heater MODEL G6A-4E. (RV built 1986) Installed new pressure relief valve. I have an ECO/T-STAT on the wall of the unit with a heat sensor valve. Could this be a problem with not shutting off? I know house water heaters have a limiting switch attached to the body of the tank. Thanks forward.
  • Many, many thanks to all of you who responded. I love the fact that we can go online and solve almost any mechanical problem with the awesome help of knowledgeable people. Thanks you again for your responses. No off to "fix" my water heater problem. You are the best!
    Jackson
  • The two parts you refer to are really easy to remove, once you understand how they are installed. They are located in the thin space between the wall of the tank and the sheetmetal housing. They are held in place by spring tension, with the weak spring pushing them tight. You may have to tap them with a screwdriver if they are corroded and stuck, and maybe bend a tab back on the tin, but they will come out.
    Step one on any trouble shooting with these things is clean electrical connections, and many problems are resolved once they are cleaned. I typically sand all the male posts on the stake on connections with an emery board. I then use a pliers to lightly tighten the female end, it necessary, and shot a little WD-40 in them. They should actually leave a light scrape mark on the clean terminal after they are installed and removed. The control board can also be dirty enough to cause issue. If you pull the multipin connector off, you can clean the contacts on the board, with a pencil eraser.
  • Thanks for the informative replies.
    I will replace the part as soon as I can. On mine it means removing the inset cover that holds all the controls. I have to remove several parts to get to it. It will not come out the front because there is something holding it in. I notice the replacement part has a spring on the inside holding it in. Foam cover removed easily...but can't remove the other two items. Never make it easy do they?
    Any suggestions on replacing the part other than disassembly?
  • Alrighty......
    When you state " water heater not turning off and releases the pressure relief valve" do mean the relief valve is popping open and BLOWING
    OR do you mean the relief valve is 'weeping'
    BLOWING....
    That is a failure of the T-stat AND the ECO
    T-stat is the normal temp controlling the heat cycles. OPENS when water temp reaches 140*F and CLOSES when water temp drops to >110*F
    Then the ECO has to fail to OPEN. It is the 'Energy Cut Off' (High temp t-stat)
    It OPENS when water temp reaches 180*F and shuts down all heating functions. When it OPENS it triggers the 'RED Fault Light' on the ON/OFF switch and 'LOCKS OUT' the water heater controls so heating can not occur.
    ECO resets when temp drops >150*F BUT 'RED FAULT'/'LOCK OUT' has to be manually reset by turning switch OFF, wait 30 seconds then turn back ON
    T&P Relief Valve is last ditch safety device.
    POPS OPEN when temp reaches 210*F OR pressure increases to 150PSI
    T-stat/ECO need to be replaced.....tank area where t-stats touch wall of tank should be clean and then both t-stats need to be held TIGHTLY against tank wall
    Weeping..........
    That is easier. Means 'air pocket' in top of tank has been lost so pressure inside tank increases when water is being heated
    Water swells when heated and does not compress so pressure will increase causing T&P Relief Valve to weep (drip water continuously)
    Air Pocket in top of tank allows for swelling of hot water and control of pressure increase
    To re-establish air pocket
    Turn water supply OFF
    Open a faucet hotside to relieve any pressure---leave open
    OPEN T&P Relief Valve..hold open until water stops running out (CAUTION: WATER CAN BE SCALDING HOT!!!!)
    Let T&P Snap closed
    Close open faucet
    Turn water supply back on
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
