howardwheeler's avatar
Apr 16, 2017
Galvanic corrosion when fastening aluminum
I'm getting ready to screw together my three panels to my RV roof. I'm making a Z bracket out of two angle aluminum pieces so I need to fasten the aluminum to the aluminum frame of the panel, fasten the two "L" pices of my bracket together to make the Z, and last I must screw the aluminum brackets down into my roof. Should I use stainless fasrteners or galvanized or something else? I've been planning on stainless but I don't want it over time to corrode the aluminum. Especially I want to protect the panel frame.
  • howardwheeler wrote:
    Sorry, but what is a URA type primer?
    These are todays two part primers that cure and seal the underlying structure.
    they usually come in two part kits. at you local auto paint stores
  • I buy SS bolts, screws, etc from Bolt Depot and they carry 18-8 and 316 SS. I buy 100 at a time and have plenty left over for other projects. It doesn't take very many from local stores to equal the cost of 100 from Bolt Depot, but you can buy smaller quanities.
    Absolutely no issue with using SS to attach my aluminum frames.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Fastening Aluminum to aluminum or to non-metallic,, Use aluminum.. The closer the metals are to each other THE LESS galvanic corrosion
    Alternative, depending on how strong the bonding needs to be NYLON
    However, if they need to be electrically bonded.. Or IF A STRONG PHYSICAL bond (Which I suspect is your case) use aluminum.
    You can also insulate the bolt from the panels, and still do electrical bonding.
  • I use nickel base anti sieze. 316 stainless is much less apt to white powder aluminum than either 18-8 or 304 grade stainless. But my stuff exists in a tropical sea shore environment. I have had aluminum based Never Sieze turn black. So I use nickel.
  • enblethen wrote:
    Use stainless!
    Suggest using oxidation compound between aluminum and on fasteners.
    X2 .. I'd dip each piece into a good 2 part ura type primer. and assemble wet.
  • Use stainless!
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
