captjohn57's avatar
captjohn57
Gas only water heater???
I now have an '02 American Eagle Pusher. My water heater is leaking and I'm planning to replace it. The Atwood model #GC10A-3E on the front of the heater says its a DSI gas only heater. There's a 15 amp water heater breaker in the breaker box. I have 2 switches in the coach. 1 turns on the gas heater and it lights. The other switch looks aftermarket (not like the others) and doesn't light the burner but I get hot water. There's a 110v wire going into the back of the heater. Also There's 2 fittings w/spade plugs in the back of the upper tank (thermostats?) and 1 large round fitting near the middle of tank with heavier wires on it (electric element?).
I don't think I'm "real dumb" but this heater has to be gas/electric, right?
