DutchmenSport
Oct 16, 2019Explorer
Perhaps the OP wants to disconnect the gas stove (like ... remove it???) and still have gas available to the water heater. Or perhaps he is replacing the gas stove for an all electric one????
If that is the case, you'll need to simply add a shut off valve or cap it to the end of pipe leading to the gas stove when you remove it???? replace it????
But "no" there is no separate shut off factory installed for each individual appliance that is dependent upon gas. The expectation is to turn the propane tanks off, then do the work on the appliance, then turn the propane tank back on.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
