Old-Biscuit
Nov 18, 2013Explorer III
The WH having to bleed the lines after sitting all night is NOT normal.
The propane being turned ON at the tank/cylinder would keep line full of propane.
Bleeding the lines should only be necessary if propane has been valved out for an extended period.
Problem in AM......I gotta go with 'enblethen'
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 19, 2026
