kerrlakeRoo
Jun 01, 2017Explorer
pin 4 should already be setup to do that. check your battery voltage with the TV off, should be around 12.5, then start TV and with trailer plugged in voltage should go up by a volt or more. If it doesnt your TV may have a blown fuse.
sorry just saw class a qx. but same thing applies. your chassis should recharge house and voltage checks with engine off and running is your key.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
