time2roll
Jun 01, 2017Nomad
MrWizard wrote:OP says 195GXL for 14.1 absorption and 13.56 float.
User manual pdf
Page 21 of the manual
Charge at 2.4v per cell , that's 14.4v
Float at 2.27v per cell , that is 13.62
With temp compensated charger
Meaning lower voltage when temp is above 77*f
Any charger with a GEL setting should be find
Your trip to Maine should be ok
Enjoy your new batteries
Also mentions bulk to be 13.56 same as float. Not sure I understand that except maybe to limit current.
Further note on next page the recommended charger is 10 amps max current.
Yes I recommend a separate 8 to 10 amp max charger (per battery) with a GEL setting if these batteries are staying in place.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
