MrWizard
Jun 02, 2017Moderator
time2roll wrote:
Is there a lower amp rated mega? Great solution although I would be at 20 amps max. (10 amp each mega)
No its not 10amps each mega, its 10 amps into each of the parallel batteries from ONE mega
the one on float will be doing nothing, until the one on the timer turns off, then with out the 14.1 volts at the battery the #2 at 13.4v starts working
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
