fj12ryder
Sep 01, 2018Explorer III
GordonThree wrote:Just reading this it doesn't appear that the system actually siphons fuel from the supply tank, since they do specify the supply tank can be above or below the generator. It would seem, since you plug the vent hole, that it relies on the vacuum created as the tank level drops to pull fuel from the external supply tank.
I have the same for Yamaha, didn't pay nearly as much.
The caps have been rolling around in a tool box for years now as I found them very difficult to use.
Mainly the height of the external tank is the issue. Too low and it won't siphon enough fuel. Too high and the siphon will push fuel past the gasket in the cap and cause a leak.
I also found the gasket material to be inferior, apparently not chemical resistant as gasoline caused one to partily melt and glue the cap on to my generator.
If I were inspired, I'd add an impulse pump like the Honda uses. No more need for a siphon, or use for the on board fuel tank.
Or am I wrong in my thinking?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
