fj12ryder
Sep 01, 2018Explorer III
GordonThree wrote:No you're totally right, it is just a syphon. Over a $100 syphon.
I don't see how any strong vacuum is going to develop inside a gravity drain fuel tank. There's no pump, fuel drains into the bowl and then gets atomized using a venturi right?
Maybe the Champ has a fuel pump and that allows the system to work, and I'm comparing apples and oranges.
It will work with the tank below the generator ONLY if the generator has a fuel pump.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
