OFDPOS
May 01, 2014Explorer
Generac 50G Voltage Regulator ?
Have a Generac PrimPact 50G 4800 Gen and last trip at times the gen wouldn't work ? Started up fine ran good just wasn't putting anything out. Other times would start it up and worked fine.
It would always pull the no worky when we needed it ! Very frustrating.
We stopped in at a Camping World back East and talked with a tech there.
And as usual we went out to the MH so he could take a peek yep it worked :( He said if it happens again , shut it off wait a min and start it back up it should work. he had replaced 3 voltage regulators in the last 4 months on the same symptoms. Is there a way to check the voltage reg ?
Its frustrating because the last 4 times I have fired up the Gen it has worked...
