azrving
Jan 16, 2015Explorer
You're welcome.
Not finding that model yet. Best guess so far is to consider it close to a 36lp.
Remove the connectors from the card
If you find the 18 wire, it should be a negative when you hold the switch to stop. It may be best to remove battery power. Use a digital meter and dont put any power in the card. Dont use a battery powered continuity light as even 3 volts positive may harm the card.
If it's not seeing it at the card, you found the problem.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
