HickoryDickoryD's avatar
Jul 01, 2013
Generac Quietpact 65 not supplying voltage output connection
A problem with my Generac Quietpact 65 gasoline generator
(model 004704-0) had been intermittent until recently. Upon starting generator it was found that about 1 out of 3 times the generator would not supply voltage to the power output connection. By shutting down and immediately restarting it, there would then be output voltage. Seemed to be a manageable nuisance. However now there is continually no voltage at the Output connection. Could the electronic control module be at fault ($186 part)?
This is the third major problem with this generator which has only
122 hours on the hour meter. If there are any more major problems after this, it's going to the junkyard to be replaced by an Onan.
  • If you are willing to replace it, I'd probably consider going the Onan route. Generac left the RV generator market, and parts will only get harder to find as time goes on.
