azrving
Mar 23, 2016Explorer
Put the switch in the positive battery cable. It's easy to have a .7 voltage drop from the power center to the battery. Check that all lugs are tight at the power center and converter connections. Be sure you have good connections to the battery and switch. Do not use a hammer crimper on any cables, use a hydraulic crimp. You may need to upgrade the wire from power center/converter to battery as it is sometimes 6 gauge. I believe I went to 4 Gauge. The farther it is from battery to converter the more voltage drop.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
