DrewE
Mar 23, 2016Explorer III
Matt_Colie wrote:
Discussion of possible corrections:
As Said, put the battery disconnect in the positive cable. You can have the cable from the PD there, but nothing else at all should be direct at the battery side of the switch and only put the converter there if you will want to charge the house bank in storage.
The trailer beakaway brake system should run directly to the battery and not be switched. Sometimes there is a fuse or circuit breaker three, but that's all.
I think this may be a legal requirement (that it not be switched), at least in some jurisdictions.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
