time2roll
Mar 23, 2016Nomad
Increase the charging loop to #4 wire to improve charging (reduce voltage drop). Battery will still charge fine just slower. Or get a second converter and mount close to the battery. 9140 is perfect for a 1000w generator although I mostly recommend solar.
Battery switch should be on the battery positive cable close to the battery. Switch really does nothing in the current position as best I can tell.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
