I run my 5th wheel on generator while on private property w/out power. I hook up to the generator on the 4 prong 30 amp output. I plug into this with a 50 amp to 4 prong generator setup i made; then ...
Probably should tell us a bit about your generator, particularly what size is it in KW? Also, on the four prong generator output, is it 120V or 240V. Might help to explain why there is a 4 prong outlet on the generator.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
