tntcrockExplorerSep 30, 2019Generator ??I run my 5th wheel on generator while on private property w/out power. I hook up to the generator on the 4 prong 30 amp output. I plug into this with a 50 amp to 4 prong generator setup i made; then ...Show More
time2rollNomadSep 30, 2019You will get more with the 50a cord into the L6-30 outlet.Half the outlet gives only half the generator power.If running just light items you can get by fine with a standard 15 amp extension plugged into the 5-15 connector.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
Related ContentGenerator noise reductionGenerator operationLeaving generator wet or notGenerator questionTC Generator swap
