tntcrock
Sep 30, 2019Explorer
Generator ??
I run my 5th wheel on generator while on private property w/out power. I hook up to the generator on the 4 prong 30 amp output. I plug into this with a 50 amp to 4 prong generator setup i made; then ...
time2roll wrote:
You will get more with the 50a cord into the L6-30 outlet.
Half the outlet gives only half the generator power.
If running just light items you can get by fine with a standard 15 amp extension plugged into the 5-15 connector.
