tntcrock
Sep 30, 2019Explorer
Generator ??
I run my 5th wheel on generator while on private property w/out power. I hook up to the generator on the 4 prong 30 amp output. I plug into this with a 50 amp to 4 prong generator setup i made; then ...
tntcrock wrote:I recommend getting a proper cord with 4 wires.
I have a generator cord I want to put a ss2-50r plug on one end. This is the end that plugs into my camper wall(removable cord. My generator cord is 4 male twist prong but only 3 wires; there's a jumper from neutral to ground. Do I wire the camper side same way? Black - hot, White - hot, green neutral and jump from neutral to ground? The ground on the camper side is just a metal plate on outside of connection that contacts camper.
