dave17352
Apr 04, 2021Explorer II
BFL13 wrote:
Interesting about the 55 amper LKs I will check that out. I suspect the 30 amps instead of 55 is from being in the WFCO's location and it has long thin wires to the battery. My 55 amper does 56 amps but I use short #4 wires with it.
You can parallel the two 55 ampers running off the big gen and get 110 amps that might be under 100 with voltage drop if you want to do 1C on the LFP that way.
EDIT--AFAIK the converter has no high current power shut down; it is just current limited to its rated current (and a bit more). Did you mean the 120v power to the converter is shut down by a generator shut down controlled by the BMS or Victron?
When I ran the converter next to the battery it definitely would cut out at higher amps. I did this several times. It would run up to 50 plus amps and cut out. When I lowered the voltage therefore less amps it quit cutting out. I could get higher amos but I am okay with 30 plus.
