BFL13
Apr 04, 2021Explorer II
Not sure what is happening with your converter. Did you twiddle the second pot inside? The PowerMax guy does not know what that pot does for sure; he will ask his engineers.
He did say he knows lots of guys using LIONs with the LKs set to 14.6v and it has been working out great for them.
If you did twiddle that second pot IMO try to put it back OEM and the pot in the hole to 14.6. You should be getting 55 amps. What does the second 55 amper do? You could copy the second pot's angle around in the 55 amper not twiddled to find OEM position.
If the low amps problem persists, please post about that some more. No doubt PowerMax will want to know too and put you right as needed.
